Selling my built AODE, hardened input shaft, FMVB with a pro brake and OD/lock up on a toggle switch, Deep aluminum pan, lokar dip stick, PTC lock up converter (3300), stifflers crossmember, sfi flexplate 164 tooth 50oz, stock shortened driveshaft, hurst pistolgrip shifter. There is more done to the inside just can't remember what exactly. Always ran Case hy-guard fluid, new filter last year. Was going to put new clutches in this year if I ran it again.
My car has been [email protected] in a 3500lb foxbody making close to 900 and this trans has held up great. The aode is super streetable with the OD at the flip of a switch. Bad ass converter but not made for full throttle in OD, just cruising. Going a different direction is the only reason for selling. My car cruised at 1500rpm in od/lu, 3.27 gear and a 28" tire.
This is everything to swap into a foxbody.
$2500
Will drive to meet within reason. No shipping
Lima, Ohio View attachment 355657
