Status
Not open for further replies.
1 - 10 of 10 Posts
Built Ford fox body 8.8. 5 lug Moser 31 spline C-clip eliminator axles with 3" studs, Ford Trac-loc differential, Richmond Gear 4.10, braced housing. New drums and wheel cylinders, shoes in good shape, could use a new hardware kit.
Housing was mechanically stripped to bare metal (never really liked media blasting, stuff gets everywhere), tubes and brace tig welded and painted in KBS Satin black (in case you need to add sway bar brackets or coil over brackets or anything, just grind, weld, and touch up paint like new).
Comes with stock style companion flange, for a direct replacement. This was built with a Ratech solid pinion spacer, so if you choose to upgrade to a standard 13xx style yoke, you do not need to replace the crush sleeve.
Brakes are not assembled, as you would have to take them off to install your e-brake cables.
Race ready, perfect for a healthy street strip car.
Prefer not to ship.
Located in Xenia, Ohio.
$875 with new Mac Diff Cover, $750 without. Not interested in selling cover separate.
It will only allow me to upload 5 pics, if you need more, please pm me.
Thanks,
Ken
Discussion Starter · #4 ·
sweet'n deal a little bit.
I have some spherical bearings and used Mac girdle I can throw into this, in place of the new Mac cover, for $875.00.
I can upload pics of them, during the week.
1 - 10 of 10 Posts
Status
