I'm looking to change to a 5 bolt pattern, hopefully withhout spending $200 on the SVO rotor kit. Does anybody know another way. I have a set of Lincoln MKVII spindles when I upgraded to larger caliper pistons. But Moog says there are no ball joints made to put MKVII spindles on Mustang control arms. How about fabricating tubular arms? If I'm going to have to spend the money I might as well do it right, huh?
Thanks for the help guys
The Mark VII front brake rotors slide right on the '87-'93 Mustang spindles. Only thing you have to change are your wheels.
For the rear use '83-'92 Ranger/Bronco II driver side axles or '86-'97 Aerostar passenger side axles and the 9" drums.
