I removed the instrument cluster from my 91 LX in an attempt to change the needle color. After removing all of the needles, sanding them and painting the backs, I reinstalled them and now none of them work.
The oil pressure gauge wont move. The fuel gauge is so far up, that I cant see the needle, the water temp gauge is constantly pegged as is the voltmeter. The speedometer and tach work fine.
After going through all this, I look at the Chiltons and it says not to remove the needles as magnetic gauges can not be recalibrated...WTF!! There has to be some way, I mean people remove the needles to install white face kits dont they?
So am I doomed to replacing them? I dont mind going to aftermarket temp and pressure gauges but I would at least like my fuel gauge to work.
Any help is appreciated.
Thank you.
Thank you.
