I was taking off the tranny pan on my PA C4, and one of the bolt heads broke off, I have the pan off now, but the threads of the bolt are still in there. The bolt never turned, so there is nothing to grab onto. What would be the best way to remove?
Moderator
Is it broken flush? If not, see if you can CAREFULLY grab it with some vice grips.
Or, get an extractor tool, wher eyou drill a hole in the bolt, then punch this tool into it, and it's got reverse type little teeth edges and lets you extract it. I assume it broke because it was frozen though? Or just carelessness... :D
Be vewwwy careful though, don't wanna fudge up your case.
