MMR is a running a sale on its 1000SE Forged longblocks for 2005-2010 Mustang GT. Replace that Worn out 5-10 year old engine with this fully forged shortblock with CNC ported cylinder heads. This engine is a Direct fit into ALL 2005 -2010 Mustang GT's
What you get:
Brand New Ford Racing Block
New USA MADE FORGED 4.75 Liter STROKER Crankshaft w/micro polished journals at no extra charge (not chinese like Eagle)
New 4340 MANLEY Forged H-beam Rods ( These US made rods are shotpeened, magnafluxed and weight matched to bring you the finest H-beam rod available for your Stroker) (not chinese like Eagle)
New FORGED Manley Bore size (any compression)
Total Seal file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A)
Clevite Tri-metal Rod and Main bearings
Complete Pro Assembly and Balancing for the smoothest, highest revving shortblock available, Pre-Lubricated with Royal Purple Assembly Lube and spin tested. Lastly 3 technicians sign off on your new engine prior to packaging and crating.
Brand New Stage 2 CNC Ported Cylinder Heads
Ford Racing Head Bolts and Head Gaskets
All New Ford Racing Camshaft Phasers, actuators chains, guides and tensioners
Ford Racing Roller Followers and Lifters
Factory Ford Camshafts
Ford Racing High Volume Oil Pump with Steel back plate and new pick up tube
Complete longblock assembly /timing and degreeing
1 Year Warranty!
All for just $5999 !!!!!!! Limited time offer
Options:
Upgrade To ARP 2000 Head studs $299
Upgrade To Billet Oil Pump Gears $299
Upgrade To BOSS Block (makes 5.3 liters) $999
Upgrade To Alloy Block $1299
Upgrade to ARP Main Studs $189
Upgrade to Ford Racing HOT ROD CAMS $660 (great for s/c or n/a)
Upgrade to Comp Cams NSR Camshafts $650 (great for s/c or n/a)
Call for questions or to order
1-877-MOD-POWR
What you get:
1 Year Warranty!
Options:
1-877-MOD-POWR
