1 - 9 of 9 Posts
My passenger side front rotor and caliper is junk, and my front drivers side rotor is warped and pitted pretty bad.
I was thinking of upgrading to either Cobra, Bullitt, or Mach 1 brakes. Aren't these all the same package, or is one better than the others? Would I be better off just getting a Baer, Brembo or similar aftermarket kit?
Will any of them bolt right up or will I need to modify my spindles?
They are the same other than what it says on the caliper. The Cobra says Cobra, and the MACh/Bullit have the pony.
ok this is what i rmeber so dont quote me
yes they will bolt right onto your spindles..if you use the 99+ spindles it will move the front wheels out a few mm..i belive 6mm or about 1/4"
I would keep my stock spindles as long as everything would bolt right up, no need to spend money on something that wont help me any.
The Cobras will bolt righr up. Just ensure that you get the caliper brackets.
David
Caliper brackets? That would be a Ford/dealership item only, wouldn't it?
I bought mine from Ford but someplaces sell them with the calipers.
David
www.mustangparts.com has the brake kit (calipers, pads, brembo rotors, and brake lines) for $399. i have a 94 gt and the brakes bolted right up with no additional parts. i only changed the front brakes, so you might need brackets to change the rears. i just painted my stock rear calipers to match.
www.discbrakesrus.com
Full cobra upgrade for 499.. they have many different color calipers and I think 2 styles.. one says cobra and one has a picture of a mustang
1 - 9 of 9 Posts
