My rear brakes started squelaing the other day so i decided to replace all the pads as well as the front rotors since theyre warped and the pads are still the original ones. The problem is i cant get either of the front caliper mounting bolts off to remove the caliper, or just the anchor bolt so i can at least replace the pads. Ive tried PB blaster and both a breaker bar and impact wrench and the anchor bolts wont budge. Ive already ruined 2 T-50s. The other problem is i cant screw in the piston on the rear calipers, and now the caliper wont even go over the old pads let alone the new ones. I bought the tool (the cube one) and none of the sides fit onto the piston. I even went and compared it to ones in other stores to see if it was the same size as theirs and it was. I also tried pliers but i could barley get it to spin. The tool in the haynes manual looks like a T handled one but everyone said the cube tool would work. Does anyone have any tips or tricks they could share from their experiences?????
Brian
Brian
