Will someone correct me if I'm wrong, but when changing the pedal assembly in a fox mustang, there are only 4 nuts at the firewall and one screw that goes through the top of the bracket to the dash. Am I missing something?
Ken
I think there are 4 into the fireway, one dead center at the top and hen i believe there are 4 more going up into the top at the corners.
Not sure though. I will look at my spare 5-spd assembly tomorrow if i get a chance
i am not for sure but i had to drop the steering column down ... at least this made it easier .. also, there are some oe locking washers that you made need a flathead screwdriver to get off of those attaching the steering column .. and with a little tug mine came right off ... just those 5 bolts (4firewall 1top) ... also .. is there a shim? that holds the pedal to the quadrant?
