I'm rebuilding and 84 foxbody I've converted to sn95 brakes. With a 95 master and booster. The issue I'm having is the brake lights come on when you press the pedal but when you press more than halfway down they shut off. Any ideas it's a new switch also
the switch is normally closed
therefore without the pedal in the fully up position, the lights will come on
once you step on the pedal the switch closes, it cannot open unless there is an issue with the switch
i would remove the switch and test it
The lights work normally. Off when not pressing the pedal and on when you are. The problem is they go off after you press the pedal down more than halfway.
did you not read my post
I did I test the switch and it functions as should. I went and bough a 94/95 switch. Which is slightly different than the fox one. And now they work fine
You were using wrong parts?
