My brake lights only come on when I step on the brake real hard. I just did a T-5 conversion and used an old brake light switch off another set of pedals. I have another switch, should I just try to put that on and see if they work, or is there something else that I should look at?
Andrew
if its not too hard to swap it out, do that and then if it still does it you can elimnate that problem.
