will the 99+ stock PBR calipers work with the cobra brackets on a cobra (13") rotor? i can ge the brackets from a cobra but not the calipers themselves and didnt know if i could put the GT PBR calipers on the cobra brackets and then be able to use 13" rotors.
any help would be great.
thanks,
adam
no you cannot.. check the pic.. physical differences (size, mounting etc)....
Adam
how are the cobra brakes any better? i dont get it, the GT pistons are larger in diameter and offer greater pad surface area. the only major difference is the 13" rotor....
thanks for the pic.
take care,
adam
The 99+ GT brakes were never designed for the 13" ROTOR. They are better because the further out you grab on the rotor the easier it is to stop.
