2003 GT
03 / 04 Cobra Bumper
I am have a new Cobra bumper for my GT. I have new (to me) cooling adapters and brand new hose. Does anyone have pictures that they can share of how they routed their hose? I can do my own trial and error or do it right the first time from someone that as it sorted out already.
Edit: So I started to mock this up today. Kind of stinks. I think my tires will rub the ducting the way I have it now. Also, I am using Allstar Performance AAF-ALL42151 duct hose. Man, this stuff is super stiff. Horrible to route and not flexible. Any recommendations for another brand?
Mine are zip tied to the sway bar and then go to the nose.
Well, I hoped that I would get this right the first time but no such luck. I routed this the way I thought would be cleanest. I am hitting the tire at full lock. With the hose pulled down and as far back toward the engine (below the sway bar) I can clear the tire but still hitting the rim at full lock. The ducts are Lambert Automotive Performance P/N 04810ST. I dont think you can even get these anymore. Rims are 17x9. The only way I think I can get the clearance to the rim is either go up to 18's or use spacers. Also, I now have the hose cut too short, a little extra lenght would help now. This Allstar hose isn't very forgiving and I will have to pull the bumper off again to refit if I get new hose. Any suggestion on something other than the Allstar? Once I get this sorted, I will post pics for posterity.
I'm on 17x9 1/2 Enkei RPF1s and they have gobs of clearance but it seems that when I was on 17x9 95 Cobra Rs I used a 1/4" MM spacer.
