Hey
I'm about to order a set of pistons for my 87 roller block
So for 0.30 over bore stock rod length and stock stroke piston it would be
4.030 bore, 3.000 stroke 5.070 rod length
is this correct?
Thx
Discussion Starter #2
your honest best bet is to call the place you are going to buy from. tell them what you are wanting, and then letting them get together what will suit you best, you might save some money from a prepackaged box and it will end up better for you!
My bad thats correct stock rod is indeed 5.090...
Well this is what i'm getting SRP forged flat top postons for 0.30 overbore with full floating pin, JE rings and Eagle SIR I beam connecting rods.
