1 - 20 of 35 Posts
· Registered
Hey guys.
New to me 1991 331 stroker Edelbrock Performer II upper/lower intake and heads.
Blew a gasket last week - I was getting on it hard in first gear and white smoke (I mean huge clouds of white smoke) started coming out of the exhaust. I limped home (6 blocks) - exhaust smelled like coolant and coolant was dripping out of my tailpipes. Coolant level was very low but temp gauge never got hot. Oil is not milky.
Side note: I was thinking that it was a blown head gasket due to pre detonation because my dumbass didn’t think about fuel octane with a stroker motor and filled up with 87 octane. This happened on my way home from the gas station after filling up. I haven’t done the compression ratio calculations (help would be appreciated on that) but I believe I should be running 91?
I started tear down and just pulled the lower intake to find a failed lower intake gasket as seen in the photo. The question is - should I assume that the failed lower intake gasket was the source of huge bellowing smoke out of my exhaust? Should I pull the heads to inspect and replace the head gaskets and bolts anyways since I’m this far?
Thanks in advance
Tire Automotive tire Hood Tread Motor vehicle
Blue Building Engineering Auto part Metal
· Registered
that happens a lot when using the gasket with rtv around the water ports on the heads and intake.
it is possible that a leaking intake caused your issues. order 1250s3 or 1262s3 which is steel reinforced and will not have that issues the current intake gasket are having.
as easy and cheap is an intake gasket sway is, i would do that first before changing the headgaskets.
· Registered
Yes to all of this.
I has similar issue with my car, but my leak was more of a weep (at all 4 corners).
Ran that way for 15 years, but it never did run right and slowly drank coolant.
I didn't discover it until I pulled engine to rebuild.
New engine has 1250s3's that rob mentioned.
I'd say good chance it's the intake gaskets, but since you have it apart, just do a compression or leak down test.
Disconnect the serpentine belt so your water pump doesn't spin while cranking if doing compression test.
  • Like
Reactions: Killer95GT302
· Registered
Discussion Starter · #6 ·
Thanks for all the input guys. It would be easiest for me to do a compression test, but I have the fuel lines disconnected. What’s the easiest way to disable the fuel pump so I don’t pressurize those disconnected lines when I turn the engine over? Or should I go rent a leak down tool?
· Vendor
Thanks! Compression looks good, thankfully. I’m assuming high compression on 1/4/5/8 is due to coolant in those cylinders. They were spitting out coolant during compression test. You guys agree?
1- 205
2- 180
3- 180
4- 215
5- 205
6- 180
7- 190
8- 210
Yes, and then use a 1262S3 intake gasket instead of that current 1262
· Registered
Discussion Starter · #14 ·
I got everything put back together with new lower intake manifold gaskets and a new upper to lower intake gasket. Engine started up and idled great, but I immediately had a lot of white smoke and coolant drips/splatter from the exhaust. I let it idle for maybe 2-3 minutes and still lots of smoke. At first I thought it might have been burning off residual coolant, but I assume that would not last that long, correct?
I’m a little confused as to what the problem could be. I thought the only way for coolant to get into the combustion chamber was from the intake or head (either gasket or crack) or a cracked block. The compression test tells me that the head, block, and head gasket are good, correct? Still no coolant mixed with the oil. Where should I test next? Looking for a little direction here, any help is much appreciated.
· Registered
Discussion Starter · #17 ·
Do a combustion gas test on the coolant
Just to clarify - a combustion gas test would indicate a blown head gasket (not intake gasket), correct? Wouldn’t this have been eliminated via my compression test?
· Registered
If there’s still a bunch of white smoke I’d just run the combustion gas test. At least you can for sure cross that off the list as the cause.
· Registered
May not show up with a compression test.
Compression test is fairly quick (meaning the actual compression stroke is quick), so if the head gasket failure was small, it might not show low compression.
· Registered
Discussion Starter · #20 ·
Thanks for all the advice so far fellas. I just ran a combustion gas test and it passed. Fluid stayed blue (or at least very, very, very close to blue). I tested it after about 5 minutes of idling then again after about 10 minutes of idling. The white smoke didn’t show up until the car idled for about 90 seconds fwiw, not sure if that means anything. Attached a few photos.
Any ideas? Did I flub up the intake gasket install and it’s still leaking? Are there any other ways for coolant to get into the exhaust?
Automotive parking light Car Land vehicle Automotive tail & brake light Vehicle
Hood Automotive tire Vehicle Automotive tail & brake light Automotive lighting
Hood Fluid Motor vehicle Automotive exterior Gas
1 - 20 of 35 Posts
