im checking out the comp cams website, and ifinally found their blower cams. im just wondering, could i use their blower cams with 1.7 rockers and aftermarket valve springs? or would that be too crazy? also, which cam would be best for basicly stock motor (heads and intake) except im going to be porting them? i was thinking either the 276HR or the 284HR. the 284 says it works well with heads intake and 3.55-3.73 gears, and i current have 3.55s. plus an aftermarket intake would be the next purchase, then heads. but the 276 says it works well with a 5 spd, but needs mass air and larger injectors............well, im going to have a 75mm mass air, and 30lbs injectors, is that good enough? HELP!
now also, another thing, if i run this blower cam on an N/A motor for a bit before i install the blower, will it hurt anything?
