1 - 10 of 10 Posts
I want a clutch that is a little tighter so I can get a little bit better controlled launchs and such, what would you recommend?
See sig. And its still hard for me to launch it smoothly everytime on the street. Its worked very well for me on the 4 passes I've made with it. I'm sure others will agree. 650 HP clutch disc.
Discussion Starter · #4 ·
so if I got the king cobra clutch kit from Gefracing, what else would I need?
what about warranty issues? if i were to swap a better clutch would my warranty go bye bye?
Discussion Starter · #7 ·
I actually had my clutch replaced under warranty, usually clutches are considered wear items so replacing it would not be a problem since, really it never had a warranty anyways, and shouldn't affect any other part of the car I would think.
IMO the best combo is the centerforce disk and the motorsport plate. I have had this combo for 3 yrs and it rocks. The hotter it gets the harder it grabs.......
Clutch
Get a Centerforce Duel firction. It has weights on it for less petal effort! The weight are small-nothing heavy. Strong griping power TOO. I love mine and so does my friend that has a 12sec, 5.0. It doesn't slip at all. Highly recommended.:joy:
I'm lovin my new spec stage II with AL flywheel and PST carbon fiber DS. You can ride the clutch a little, its not just on or off like higher hp level clutches.
1 - 10 of 10 Posts
