Hello, where is the best spot for an Intake Air Temperature sensor on the 302?
Some people say it should be in the intake air tube, others say the upper intake plenum, others say the lower intake manifold. The stock location is on the cylinder #5 runner in the lower intake manifold, but I've read that heat soak will affect the sensor. I have a phenolic spacer and expect the upper intake is going to be a lot cooler than the lower. Should I weld a bung to the intake air tube and position the sensor close to the throttle body? Or should I install it down in the lower manifold stock location? Or the upper manifold somewhere? Or does it even matter since I'll be using a Microsquirt ECU? I assume I can calibrate it in the software...
Help appreciated, thanks.
