1 - 19 of 19 Posts
I was just curious what your best e/t is for 94/95 gts with a stock bottem end running n/a? I wanna be around a 12.7 i think i can do it. whats your best run N/A?
13.2 @ 104
3700 lb convertible, automatic.
See my sig for the times that was the best that it ran on a actual 1/4 track. I gave gone [email protected] in the 1/8th since then which is about a 12.73 or so at 107.5. Those are roughly converted from the 1/8 time based on a NHRA chart that I have.
12.73 was my best ET
107.30 was my best MPH
It will run 12.8's at 106.6-106.9 all day long on my daily driven Nitto DR's. This is in my nearly 3700lb 5 speed convertible.
Best ET: 12.991
Best MPH: 106
Those times were in terrible conditions. New times as soon as I get the heads back and the tracks open back up.
-Billy
13.7 @ 101 on DR's with a 2.1 60ft WTF?... 3.55 gears, aluminum ds, flowmaster exhaust, Cold air kit, LT's, Cobra Intake, off road-h-pipe.
a friend of mine ran [email protected] in his 94 GT. He has E cam, edel heads and performer intake, 3.73s, full exhaust, T/B, MAF, 24# injectors, CAI, etc. He ran it on 275/15 BFG DRs on a cool night up in norther New York. We were all stunned by how fast he want N/A, with stock computer! No chip, no tuner, nothing. Full weight GT too.
you can see my mods in my sig, basic bolt ons, and stock heads and cam. I will be running a 12 sec pass tommorow. I have run low 8.2's in the 1/8th mile.
All it takes is lots of practice, and good traction.
Hello, I have a 1994 mustang with trick flow 11r heads 190, edelbrock performer intake with 1 inch spacer, cold air intake, 75mm BBK throttlebody, 24lb injectors with maf sensor. I also have dot slicks. My best time in the 1/4 mile is 13.9 at 100.5 mph. Am I new to drag racing. Is my setup maxed out or am I doing something wrong?
You have a potent combo there, keep working on it. What was the 60', what trans and rear gear? Off the cuff, I would say you have mid 13's in your future. At least?
My best 14.089 at 100.58 with 2.215 60'. Stock converter, stock cam with crappy 555r's
I have a buddy that had a similar combo except the heads were 170 holley systemax heads, intake was tfs street heat and he had a b303 cam. Was going 12.8 on 17” rims and street tires. T5 and 3:73 gears
I have a 95 cobra. I pulled the seats out of it and just put a plastic seat in for the drivers seat. Afr 165 heads. Comp xe 270 cam and a edelbrock rpm 2 intake. Ran 12.75 at like 107 and the car was needing retuned at the time. Now I'm running an ed curtis cam 11r 190s and the rpm 2. Car hasn't been started yet but I'm sure itll pick up quite a bit. What cam are you running Rob?
1 - 19 of 19 Posts
