Can having a belt that's too tight cause a problem? I bought a new belt and it was a bitch to install. I ended up using a prybar to get it on. It was the same number as the belt that was put on the car before. It's not the original belt though. I'm guessing it was changed when the S-Trim was installed.
The tensioner is at the extreme end of it's range. If I push down on the belt slightly, it'll reach it's full travel. Should I get a longer belt or just leave this one in. I've been driving it around pretty hard to try to force it to stretch too.
Thanks,
Henry
Thanks,
Henry
