65 fastback pump gas .060 289 (297) solid roller, T5 all motor. 11.12 122 mph
Factory 302 rod from an earlier engine. Showing this so you can see the parting line down the beam.
Yours is longer. Doh!
I'd ground down that seam on several junkers I put together, wondered if it was worthwhile to make the sides flat, or just smooth it out so parting seam was gone.289 rods out of my engine. Beams ground down flat, balancing pad completely ground off the small end, shot peened for a nice uniform finish and better rod bolts. For the people who wonder why those old 289‘s could hold together at higher RPM. Here is your visual.
Option 2I'd ground down that seam on several junkers I put together, wondered if it was worthwhile to make the sides flat, or just smooth it out so parting seam was gone.
That's what I've done, never ground them flat, seemed to me like it would weaken them.Option 2
It's difficult to make something stronger by removing metal.That's what I've done, never ground them flat, seemed to me like it would weaken them.
