I am planning on taking my car in to have BBK longtube headers (1 piece) and matching off road h-pipe installed on my 00 GT. what gaskets do i need and where do i get them? what type of header bolts do i need? and lastly, do i need an extension wiring harness for the front o2's? thanks for any help
It has been my experience that the factory studs and nuts hold stronger than header bolts. The ford gaskets are also excellent pieces. You will need the O2 extensions but I would personally re-use the studs and gaskets.
Later,
John
I reused my studs and gaskets
Dave
Discussion Starter · #4 ·
cool. then the only thing i need to supply are the o2 extensions? were can i purchase these?
Formerly FL Zinc
Dallas Mustang has them. You could just lengthen the wires and splice it all together.
My car had only 23k miles.
I reused the factory studs/nuts and gaskets.
You can order any extenders, you shouldn't need to splice anything.
You will need MIL elimnators, these also require no splicing.
Matt
