75mm BBK Power Plus throttle body and Edelbrock 75mm EGR spacer for an 87-93 Mustang or 95-95 Lightning.
These came off my 94 Lightning, so the breather tube on the throttle body was rotated 180* to accommodate and can be turned back around for a mustang. The EGR spacer had a bracket welded to the side to accommodate the Lightning's throttle linkage which can be cut off if need be. I also removed the coolant tubes from the spacer and installed 1/8 pipe plugs, but these can be reinstalled with 1/8" NPT pipe nipples.
Asking $150 for the set plus shipping.
