1 - 10 of 10 Posts
I have a Griggs k member and I am tring to install a set of BBK 1 3/4 long tube headers and the steering shaft at the rack end hits the header. Does any one have a solution for this?
I found another steering shaft, cut off the upper u joint and welded it into place of where the stock rag joint is and then welded the rack connector that bolts onto the rag joint onto the end and had plenty of clearance
or you can try denting in the header
or buy a flaming river shaft
hammer.........nothing is a bolt-on :)
i have the same setup. no problem at all. first you have to removed the steering shaft. installed the header, then put back the shaft, it should have about 3/4 inch clearance. also you can run the flamming river shaft, it has a lot more clearance.
Yeh
Use solid motor mounts. Then it wont move around and the old ones are probably wore out anyways, mine was over and inch low when I put the LT headers in, I couldnt even put the headers in until I got the solid motor mounts.
Thanks for the info guys, I think I am going to try a Flaming river steering shaft.
Check your motor mounts. I run factory NEW convertible motor mounts and my BBK 1 3/4's clear the shaft just fine. Don't waste money on the Flaming River shaft if you need motor mounts instead/also.
i took the wheel off, removed the steering shaft, and stuck a prybar in there and dimpled the header.
I don't know about you guys, but I don't like to dimpled the hot jet coated header lol. try removing the shaft, installed the header, if it still hit, flaming shaft is your only option unless you try to hammer it.
oh.. didnt see they were jet hotted. yea i agree lol.
i have macs with the super duper RUSTY hts crap.
1 - 10 of 10 Posts
