1 - 14 of 14 Posts
I am installing a Baumann shift kit into my AOD along with an Edge converter from Andre.
This car will be 95% street driven, 2% drag strip, 2% highway cruising to FLA etc.
I want to be able to have it be fun from light to light on the street, yet be docile enough to enjoy driving it casually when I am not pushing it to the limit to beat a 'vet.
Can anyone tell me how they set up their Baumann kit and how it drives and if they'd do anything different?
Thanks!
on my wifes AOD car i had 1st shift out at 5200 and 2nd to 3rd at i think 4800-4900, I SHOULD have taken 2nd to 3rd at 5200 and left my 1st to secound rev longer like 5400, the baughman shift kit moves them both up but it does-not even up the diff, if you know what i mean, so to do over i would let 1st to secound over rev a little, and on the firmness i think i went with the mediume setting and it was too hard -untill i put the 2800 NON lockup converter in it and it seem to soften the shifts up to about right
Set the 1-2 shift at level 2. Level three will break your neck. Level two will shift firm but not harsh at part throttle, but chirp the tires at WOT.
Set the 2-3 at level three.
I did it this way and was very pleased with the results.....
I installed a Bauman kit in my F150 with an AODE. Seems like I went with level 3 across the board. It has a very quick/firm shift w/o being harsh. I'll have to look at the paperwork when I get home. I will add that Bauman as a company is great and I'd use them again in a heartbeat.
It's been so long since I had the car running, I don't recall what RPM the stock tranny shifts at.
Does anyone recall or know?
I would like to increase the shift rpms to match my camshaft and gears etc.
Sounds like level 2 is what I am looking for on the shifting. Crisp firm shifts at part throttle, and chirping on WOT. Very nice.
Thanks guys.
if i remember right--- by the stock tack when the trani was stock it shifted from 1st to 2nd at 4800 and 2nd to third at 4500 , so make shure you take 2nd to 3rd to the right point and let 1st to 2nd over rev a little
Just be careful you don't go too far, or you will be pulling the VB to re-do the TV shims........
Mine would barely shift before the car quit pulling altogether.....
Sounds like Medium setting is it for me then.
One question, when increasing the shift RPM, does it always shift at that rpm regardless of engine loading? Or am I only modifying WOT shift points?
I wish I knew what RPM this tranny shifted at before I pulled it out.
I guess I can increase the shift rpm a little based upon guessing, then increase it more if I need to.
I think my cam in the old manual '86 car liked to be shifted best at 5200 or so. Will this change any with a torque converter?
I had a Baumann kit in my 93 AOD LX. I went with 3, but after driving it for a few weeks I hated it. I went back to Ford and bought a new seperator plate. I did the level 2 and it was the best choice for me. I believe the seperator plate is no longer sold seperate from Ford, so when you drill the holes make sure it's what you want. Otherwise you'll have to get a new valve body to fix your mistakes. I talked to Baumann after I drilled out the holes. They recommend to me for everyday driving to use stage 2.
Hope this helps......
Andy
It only increases the wot shifts. If it increases the part throttle, it isn't noticeable......
Discussion Starter #14
I will go with the medium setting for now, as was mentioned, I can always pull it and increase it later if needed. This is a 95% street car and I would like it to behave calmly when not at WOT.
At WOT I would like massive performance though!
Thanks guys.
1 - 14 of 14 Posts
