Ok I am wanting to get this switch hocked up and working right. Ok I take the positive to one side of the switch and run from the other side of the switch to what? The starter or the altenator? So that it kills the car while it is running. Any help would be great. It is a 98 GT if that helps anything.
Take a look at the SSOTN tech article by Fred Bingham, he outlines it very well. It's based on a fox body car, but is easily adapted to a mod car. In his instructions he says to run the power cable from the switch to the starter solenoid which is where the battery is originally wired on a fox, for a modular you run it to the fuse box in the engine compartment which is where our battery was originally wired to. Other than that, its all the same.
http://www.superstallions.com/tech/elect/bat_relocate/bat_relocate.html
