1 - 20 of 28 Posts
:eek: Scared the pee outta me! That hydrogen stuff is really powerful! The instant I turned the ignition on I hear this really loud explosion, seemed like it came from under the car until I opened the trunk and all this acid smoke billowed out. Battery looks like someone put an M80 in it because the sides are shreaded out and the top broke off. Nasty acid dripping on the garage floor looking like a wounded Alien was in the area somewhere by the way it bubbled when it hit the floor.
Anyway, cleanup time.
One other thing. I have an area of black soot on the TFI module and distributor cap that seems to have come from the TFI module. Time for a new one I guess?
EDIT: See how much it scared me, I couldn't even spell EXPLODED in the title.
lol Thats funny but at the same time that sucks too. Sorry to hear that happened, ever try an optima?
Never really seen soot by a tfi module before. Your probably right you probably need a new one its probably fried, might wanna check the wiring that runs to it make sure its not burnt.
What kind of battery WAS it?
That doesn't sound good.
Any other damage besides the anchor that used to be a battery??
Good luck with the cleanup...
Stan
LOTS of baking soda......kill that crap, sorry to hear. Sounds like a 12 gauge eh?
I had one blow up in an underground parking garage........holy crap!! 12 gauge nothing......more like a howitzer, with all the echos....:eek:
I have witnessed a battery blow up. Sounds like a gun shot. Some kid in my old apartment complex had his blow up and left a nice dent in the hood also.
If you don't neutralize the H2so4 acid it will continue to do damage for a very long time. Use a basic solution of baking soda and water and scrub the hell outa everything...wires, connectors, everything!
I recently read a technical paper on battery technology. The author was an Engineer for a major battery manufacturer. He described the explosive event as "spontanious dis-assembly"
I thought that was funny.
Corral Charter Member
so, what caused the battery to explode anyway - or I guess I should ask WHAT causes any battery to explode?
I am assuming it was just a regular acid battery and nothing fancy or aftermarket such as an Optima, etc?
Be careful cleaning up that mess around any painted surfaces as well, the acid will do nasty damage to body panels and such.
Sorry to hear, but I'd like to know what caused the thing to explode before just plunking in another battery, if it were my car...
Mine was a hair-line crack in the case.....and I was jump starting it - spark & gasses=BOOM!
damn man that sucks.....clean that **** really really realy well, get it all make sure you dont miss any of it ...or your going to be dealing with a good deal of rust some time soon....and trust me you dont want that....
Hydrogen gas is one of the most flammable chemicals on the periodic chart of elements.
Discussion Starter #12
Thanks for the tips on the cleanup. I think there must have been a spark at one of the terminals, not the main battery but the secondary terminals that have accessory wires attached (this is a Kirkland marine type battery). Guess I'll need to check those connections on a regular basis to make sure they are tight.
John, how well did that 1/8" thick Summit Battery box contain the explosion? Any pics......? I hope it cleans up well, that car is way to nice to get eaten up with acid....
Discussion Starter #14
Battery box held up fine Ron. I do notice some white areas of corrosion on it though. Going to get in there and scrub it up again. Only thing worth a pic at this point is the FUBAR'd battery but it's just junk now.
How are things progressing with your stuff?
Discussion Starter #15
DP
I was under the impression that that was why you don't put a regular battery in your trunk. That you need a sealed battery like the Optima that doesn't emit gasses.
Is that Right?
So it was the gasses that exploded like a fuse and then blew up the battery from the inside out?
Well, I hope everything cleans up for you. My stuff is on hold for a few more weeks. We closed on our new house(with 5 car garage(s) last night, so I will be moving and painting and expoxying floors. The car is almost complete, lacking only the MSD wiring and the battery cables. I am glad the batterybox contained the schrapnel though, at lest there are no dented body panels.
That's a Costco battery, right? Take it back and they might give you a brand new one for free, legal liability and all that. I never heard of any marine battery blowing up.
If you overheat the battery, hydrogen production happen.
Hydrogen is heavyer than oxygen so it will settle in the bottom of the area it occupies, until its full.
Then it will overflow to fill another area below.
If there is no ventilation, it will stay there.
If you had a hole in the bottom, the hydrogen would have escaped, and no boom.
Makes my think to vent the garage. (or park outside!)
1 - 20 of 28 Posts
