1 - 20 of 101 Posts
Steel Ball Joint Spacers for SN95 to Fox Body 5 lug spindle swap
Ball Joint Spacer set for the SN95 to the 79-93 Fox body a-arms and ball joint. the are Laser cut from A36 High carbon plate steel.. not cast iron or stamped from cheap scrap steel like a washer. Correct thickness fit for the 5 lug sn95 to fox body front spindle swap .. no need to use stacked up flat washers or thin Ebay spacers ... these are Painted gloss black or can send them unpainted. $17.95 per pair shipped ...
Discussion Starter · #7 ·
I pretty well have standardized on painted Black for these., if you want unpainted let me know otherwise I will send black.. thanks..
Discussion Starter · #10 ·
sorry photobucket is having problems with photos past few days.. they should be back soon...I can email one if you need them..... roy
PhotoBucket site seems fine for now.. thanks. roy
I will take a set pm me your paypal
1 - 20 of 101 Posts
