No sir no codesIs it throwing any codes?
Not even code 11 or 99? Check the basics next, spark, compression… also if you have a volt meter, check the coolant temp sensor. If it’s faulty it can dump fuel.No sir no codes
Thank you sir I’ll check that once it warm up.Not even code 11 or 99? Check the basics next, spark, compression… also if you have a volt meter, check the coolant temp sensor. If it’s faulty it can dump fuel.
After, it doesn’t smoke as much but just feels like it’s going to cut off. One other thing is it has a strong fuel smell also.Black smoke is usually over rich. Did you change the parts before or after the black smoke?
Thanks for the feedbackIf it won't send any codes when scanner is hooked up not even a code 11 the ECU may need R&R. Capacitors, power supply, etc.
BBK cold air intake, MSD distributor, aluminum radiator, shorty headers, T56 six-speed manual transmission, Ford 8.8" 3.73 rear end just a few upgradesAny mods?
