i THINK i have a bad coilpack, but i'm not sure. The car will run like it is missing and shake and sound like crap then will switch over to running strong like someone flipped a switch.
It also behaves like this while driving, it can go from running perfect to running like its on only 7 cyl.
Also, when the car is idling and the fan kicks on it sounds like the car wants to die.
It's not bad gas b/c this has been going on since early august.
do you think this is ignition related?
bad coilpack?
thanks Jason
When my car was doing the same exact thing it turned out to be intermitant splices in the MSD wiring. So yes I do think it is ignition related.
I thought 2001 Cobras have coil on plugs and no coil packs. Could be a bad plug wire.
Jerome
hmm, I have the Same symptoms. Guess i gotta check my coilpack plug
