I have a B&M super cooler and just installed a 3000rpm lockup converter. Is this cooler big enough to cool off my AOD? The cooler has been in my car over a year now and it has kept the fluid nice and cool and a clean color, but with the converter installed I am unsure about it. Are there bigger, better coolers out there?
If you have the 28,000 gvw rated on then youre good to go. Thats about as good as it gets and should be fine for the stall you are running. Now if you were running a non lock up with a ginormous stall then i'd consider adding a fan.
