Going to 5 lug conversion. Got everything off a 95 from a salvage yard. Problem is when I went to get the rear axles, they "couldn't find them". 3 days later they called and said they "found them"????
I went to pick them up. I noticed they were about .75" longer than an old set of 7.5 axles I have, but there was no ABS ring on them. Does this ring come off easily like a brake drum or is it milled as part of the axle? I questioned this and they told me the axles came out of a 95 5.0.
The axle looks identical to a 4 lug 8.8/7.5 with 28 splines other than having 5 lugs and about .75 longer. Is this the correct one?
Attn: Redsnake95
Jim,
I posted this question to another post. Look for an answer in Attn:Redsnake95.
See ya!
David
