1 - 1 of 1 Posts
2001 Cobra
After months of sitting in the box, I was up to midnight trying to install my Lunar 4163 Fuel Pressure gauge. I hooked the "black and white" wires straight into the fuse box. Lights work. The "red" wire called for a 12v supply. I tried a couple of different 12v sources in the fuse box, no luck. The gauge will not give a reading. Do I have to find a wire that is 12v constant through cranking? :confused: If so, where do I find this source.
thanks
peter
1 - 1 of 1 Posts
