Im currently in the process of changing my front end combo. Im going to be using D&D Kmember & Lakewood 90/10s. Here is my question, The Lakewood Struts come with sleeves that are about 3/8 inch thick, where do they go ? Do they go underneath the strut before the caster/camber plate or ontop the caster camber plate ? It seems like they would have to go on the underside because the cap ontop the spring hits the strut tower without spacer.
John
John, not entirely sure what sleeve you are referring to. If its the strut's dust sleeve, I discarded mine.
What C/C plates are you attempting to use with the D&D kit?
Shoot me a PM, or call me, maybe I can help out further...
joe
I know the sleve you are talking about. Best I can remember it goes under the C/C plate to allow you enough thread to tighten up the strut without bottoming out. Don't forget to knock that collar off the 90/10's or the coil over sleve will not sliip down over it. Hope this helps.
Chad
Joe thanks I wont be working on it until Monday now but I will call you. Please shoot me a email with number and time you can be reached. [email protected]
Chad thanks thats the thingy Im speaking of, I did grind the collar off which pissed me off, my 70/30s didnt have the collar.
