Looking for a great mechanic who will charge a fair price to change the crankshaft in my FFR Cobra kit car. The engine is a 92 5.0 stock short block with afr 165 heads, KB supercharger, 1 5/8 FMS headers, etc. Just had a Fordchip tune. I have a garage, an engine hoist and a variety of hand tools if needed. It appears the crankshaft broke between the timing chain and the first cylinder... timing chain cover will need to be replaced as well and will probably upgrade the clutch and flywheel while everything is out of the car. The kit car is a blast to drive and of course the mechanic takes the first ride after repairs!
Phil [email protected] Thanks for your help.
Pull motor/ pull heads and take block to a machine shop you probly have a lot more damage than that to the block! Of course I am assuming that you know how to use the garage, an engine hoist and a variety of hand tools.
AcidAngel_5.0 said:
atlanta chassis dyno
brad brand is the owner
www.acdyno.com
local store on the northeast side of atlanta
off of sugarloaf close to sawuanee
What he said
Atlanta Chassis Dyno
1855 Buford Highway, Suite C,
Duluth, Georgia, 30097
Phone: (770) 623-9789 Fax: (770) 623-8077
Thanks for the help. I posted the same thing under "superchargers" and have found someone 20 miles away who has a lot of experience and will do the work for a very reasonable price (labor only less than $400).
Phil
