I installed a set of TFS Twisted Wedge heads many years ago (1999 maybe) and used an ARP head stud kit (ARP-154-4005).
Now I think my drivers side rear stud might be leaking coolant. I used ARP thread sealer way back then, but maybe not enough of it. So I was thinking I could remove that one stud, add extra thread sealer and retorque it, or retorque them all as recommended.
Anyway, the problem I have now is my studs don't appear to have 3/16 allen-keys machined on the top. Is it possible I installed them all upside down, or is the allen key insert a later addition?
I might be able to double nut it, if I can find two thin 5/8 nuts... but room to swing wrenches in that location is really tight.
ARP studs are coarse thread into the block and fine thread on top, so you really can’t install upside down.
Those studs are 7/16”, not 5/8”. Go to your local hardware store and get a couple of 7/16-20(fine thread) jam nuts, they’re thinner than “standard” and will probably fit better when you try to remove the one stud with the head still on.
Rusty
Allen keys broached onto the strud were an addition in the 2000's. They were not on my arp studs when I built my original motor in 2000 and were there when I built the second motor in 2008. Do as Rusty suggested and get 2 thin nuts, jam them together and unscrew the stud - with a wrench or ratchet, not an impact - and you should be fine.
