I'm wondering if any of you guys that are running this set up with stock rubber(245's) have traction problems? Also I plan to get a Diablo Chip to fix the shift points and speedo, but wanted to wait a bit until I get some more mods in, How bad will the car drive with the 4.10's in with no correction? Thanks!
I think 4.10s are the way to go with your auto if you are going to go to the track often. I have 3.73s in my daily driver 96 GT auto and they are fine for me. As far as driveability with stock rubber and no chip, I think you are going to have some tricky experiences. Traction will definitely be a problem and be careful about hitting WOT at medium to low speeds. Without a chip to correct the shift points, you are going to hit the rev limiter often.
When you do get the mods you plan, you are going to be pleased with the change in your GT.
