I just installed a pi3000 stall and i added synthetic fluid to my aod and cant get an accurate dip-stick reading........how many quarts are you aod owners putting in your transmissions ? I currently have seven quarts in.............
Sorry I have to ask this first, you put fluid in the converter before installing right :confused:
I hope so......:joy:
Ian
11-13 depending on converter size and tranny cooler setup.
hey chuck are you sure on that 11-13 because that seems like alot. well what is it 11 or 13 we gotta know.....right now we got 7 quarts in it right now but the dipstick seems to not do much for us so how much is needed?
When I had a stock converter, no extrernal tranny cooler and a stock pan, I think it took 11 quarts to completely refill it after draining the pan and the converter. With a smaller converter and a tranny cooler and maybe a differnt pan, it could be anywhere between 9-13 quarts actually.
I'd start with about 5-6 quarts and keep adding until it comes up on the dip stick. May sure you move the gear selector through the gears while refilling
