is the aod to c4 a good idea and if so what is the process.
thanks
c-4 works better due to internal gear ratios and shift ability.
aod is only for those that want to drive on street and have engine run a slightly lower rpm in high gear.....
gear ratio's are the same???????
I can build an AOD tougher than a C4 for sure, and I think the C4 is a great 700ft lbs or less racing trans, the AOD for street is the way to go.
C4 for racing or weekend cruiser....if you street/strip/driver...keeping the AOD is a better option.
