I just got my Tri-Ax, and it says one has to put in a 12v switch to engage reverse? Is that right? Had no idea when I ordered it that I was committed to that? Help!
Nope you will not have to wire it if you dont want. You can still use reverse but it is a little harder to get in, you kind of have to force it over and up, you get used to it quick tho. i am 5'6 and 140lbs and have no problems with it, and i drive the car everyday. If you do want to wire it, you need the harness from a corvette/transam/camaro and you wire it to either a switch, or most people wire it to the brake, so when you push the brake you can put it in reverse.
