1 - 20 of 21 Posts
LIST YOUR ET AND COMBO ,FOX OR NS95:D
500 at the crank or at the wheels? I was prolly putting down about 470 at the wheels with mine. 14# s-trim, TW heads and performer intake. Stock TB and shorty headers. Fox.
I would like to see this as well.
How about 500rwhp with tiny 2031 cam and stock heads? :D
BBBad 5.0
I see we another evansville guy. Cool.
We will have to meet up sometime.
With stock heads is impressive! How about with a stock cam??:p
I made 612 rwhp with a TFS #1 cam... holley intake, TEA TW heads, Vortech T-trim, aftercooler.
My friends car with 98,000 miles on its original short block put out 497 rwhp with untouched Edelbrock 6037's, stock cam, 1.7 roller rockers, shorty headers, 38lb injectors, TFS Street heat intake, S-trim @12 lbs of boost, and a power pipe. Lots of power to be had with the stock cam, still idles, drives like a stocker.
At what RPM did the power start falling off. I have thought of going with the stock cam and 1.7's but i don't know at what point the power will fall.
How is the idle? Do the 1.7's cause it to have any lope? How much more lift do the 1.7's provide with the stock cam? I know there is a formula but I am not sure what it is.
Idles perfect. The 1.7's make the stock cam into about a .474 lift. He's been very happy with the combo. Still has a/c, power steering, etc...
Stock cam with a SC definitely sounds stock, well except for the whine.:)
I am just kinda curious if I went with the stock cam, 1.7's in my combo below and put the 9lb poerdyne on, what Kinda RWHP should I see or would I see more with the stage1 and 1.6's?
Friends car put out 430 RWHP before the power pipe, and custom chip. 10lbs of boost. I'd definitely upgrade your injectors, if you weren't already planning on doing so.
Formerly BLOWN1989SALEEN
the duration of the cam has more to do with lopiness than the lift itself;)
505rwhp and 10.80's with a stock cam....see sig below
Good luck
11secA-trim
freezy74 said:
hey andrew, do you have a graph of that pull?
also, hows you car coming along?
The car is coming along.. I've been slacking on getting the new tranny in. It's getting there though! I'm hoping for some 9.20's or so when it's changed out.
1 - 20 of 21 Posts
