I'm running the old school Steeda quadrant, but the adjustable cable bit the dust.
I replaced the cable with an OEM ford one, and got the Steeda firewall adjuster.
Pedal feel is much better, but I cannot turn the firewall adjuster by hand, I had to use a wrench to tighten it. Is this normal? Sort of defeats the purpose if you ask me.
Super Moderator
MIne turns by hand, easily. TOO easily. Like many others, I've had to put a little RTV on the threads so it won't walk adjustments. I don't know why yours would be so tight.
When you pulled the rubber isolator off the clutch cable did you trip the 4 little teeth off that are on the plastic part of the cable that slips into the firewall adjuster? I know I had to cut them off to get it to slip into the adjuster. Mabey you need to trim them a bit better?
Discussion Starter · #4 ·
yeah I definately removed the 4 white teeth when I removed the rubber isolator.
Fortunately the adjuster does its job, but it pisses me off that I had to futz around with a friggin pipe wrench to adjust it.
The thing turned fine before I put it in, it's almost like something's binding, but I can't imagine what.
