i just put trick flow stand valve covers on my 94, and i cannot for the life of me figure out how to make these things work. i can't figure out how to use the vacuum off of the CAI for a crack case ventilation. i don't see how to put a filler neck or anything on there because the throttle body and CAI is in the way. anyone pulled this off? pics are always great. thanks alot!
take the oil fill off your factory vavle cover, and weld it onto the tfs one. to make lifer simpler, i would just convert to a 87-93 throttle body setup if you dont care about emmisions.
The older 87-93 setup got rid of alot of headaches, and it looks cool, and probably gives me some extra power too.
whatever you do, good luck! post some pics if you can. those vavle covers would look baddass!!!!!
-nate
what all would i need to convert over to that?
you need a 87-93 throttle cable, egr plate, throttle body, inlet elbow, tps sensor, iac sensor...and inlet tubing. mark from x2cmototsports does this swap ALL THE TIME. call him up to be sure what you need, he sells accufab t/b also.
818 901 8000, tell him nate sent you
-nate
Discussion Starter · #5 ·
do i need a new cruise control cable too?
