I wiped out a thrust bearing late last year, had the crank repaired, car ran great until this past April, wiped out another thrust bearing, and unfortunately cracked the crank this time, also had evidence of main cap deflection... needless to say I tossed a bunch of $ $ $ right out the window...
I ordered my Eagle rotating assembly from AD Performance, and nowhere on their website did it say that these kits were transmission specific. Of course when everything was at the machine shop, their Eagle catalog listed my replacement "ESP" crank as not for use with AOD or AODE transmissions.
Called Eagle and the guy was like "Lemme guess, you're running an AOD and you keep wiping out thrust bearings???" Gee, thanks for the info.
I guess ultimately it's our fault for not checking initially, but...
Apparently the counterbore at the back of the crank is too shallow causing the converter snout to push forward on the crank. Turns out I only had about .025 clearance, and I was told that the flexplate can flex .030 and maybe a bit more with a high HP car. Took .075 off of the converter snout and also shimmed back the converter with some washers and set pullout to .125 so I should have around .115 clearance now, hopefully I will be good this time.
Kinda pisses me off because if Eagle or AD Performance had made this little fact known, I'd have save a lot of money and downtime. Hell, even Eagle's own website makes no mention of this. Their catalog is the only place I've seen this issue mentioned.
Jut a heads-up, watch out for the Eagle forged cranks if you are running an AOD.
