1 - 20 of 22 Posts
Not the Jeg's/Kaase heads, but the regular Jeg's aluminums. Has anyone heard anything about them? My buddy is looking into them and wants to be a little different, and he wants to be the guinea pig for us Mustang dudes. What say you? :cool:
I think they are made by Canfield, so are good heads.
do you think they make good power?
I have no firsthand knowledge, and they are not popular in this little corner of the USA, but I think they'd be very good heads. I've seen the larger Canfields (197's) , and they had some unique features. Canfield doesn't advertise much, but I think they have some excellent engineering behind them. The Ford "Z" heads look very much like Canfield's to me.
Discussion Starter · #5 ·
I might just decide to be a guinea pig also.
They flow very close to the AFR 165's. Made almost as much power on the engine dyno in a MMFF test. You wouldnt notice the difference on the street.
Discussion Starter · #7 ·
I think you are referring to the Jeg's/Kasse heads, no? If not, then awesome!
I say why be a guinea pig when there are so many proven heads out there. I would still like to see some results however.... Good luck!!!
Discussion Starter · #9 ·
see thats the thing. they could be great, and people want to know. atleast ill be different,, thanks!!
I hear you there. Dare to be different. Sure it can be a PITA, but WTH.
From what I know of them they should be in line with AFR165, Edelbrock Performers, and others in that range.
ntake
Port Volume: 170cc
Valve Diameter: 2.02'' Stainless Steel # 555-20560
Port Dimension: 1.148'' x 1.920''
Flow Rate: 254.9 cfm @ .700'' lift 28'' of water
Gasket: Fel-Pro # 375-1250 or Mr.Gasket # 720-5832
Exhaust
Valve Diameter: 1.600'' Stainless Steel, # 555-20566
Port Dimension: 1.289'' x 1.381''
Flow Rate: 198.2cfm @ .700'' lift 28'' of water
Gasket: Fel-Pro # 375-1415 or Mr. Gasket # 720-5929
Valve Train
Stud Size: 7/16''-14 x .750''(bottom) 7/16''-20 x 1.900'' (top), ARP# 070-100-7101
Guide Plates: Custom JEG’S # 555-20523 (5/16'' pushrods)
Retainers: Chrome Moly Steel 10 degree, # 555-20530
Valve Locks: 10 degree
Pushrods: 5/16'' Heat Treated, Must Check Length
Springs: 1.440'' .580'' Maximum Hydraulic Roller JEG’S # 555-20540
Spring Cups: .570'' Inside Diameter Locater, .060'' Thick, # 555-20555
Discussion Starter · #12 ·
thanks for the numbers
If my AFR's get damaged in shipping, I'll be the guinea pig for the Jegs/Kaase heads.:evil: Everyone keeps talking about them and no one has used them. I'm almost hoping that my heads fall off the truck! If everyone does the same thing, then no one will know if there is a better way. This board pushes the AFR/FTI cam combo to death. I am determined to make the most of my XE282HR. If I go custom, it will be from Comp cams. I don't care how much someone thinks they "know" the sbf, the major cam manufactures have decades worth of R&D and the best equipment to determine what is right for you. That's just my opinion though.
Be different. If you're wrong, at least you weren't afraid to try.
Discussion Starter · #14 ·
werd
the jegs/kasse are on my list to buy just have to get the money together for them
Do you guys think the Jegs/Kasse heads would be too much for a 357 cu in windsor? I mean 240+ cc intake runner! MM&FF tested those heads on a Dart based stroker. I am wondering if the $1600+ for heads and Valve covers, I could get a set of heads that better suit my combo.
those #'s look good....try 'em hardcore!
White93pony, a 240cc head is too big for a 357......Unless it is an svo block and you are turning it to 8-9K....
depending on what you want to do, the regular jegs head would be nice on a street/strip 357....
Banned
awesome. I have something like that, theyre called avenger heads, i didn't put them on but found out that they are or were made by canfield. They have very similar numbers and i am very satisfied with them.
tweak302, what did the rest of your combo look like with those avenger "canfield" heads? 302 or 351?
Banned
cobra intake, 24#, afpr, shorties, catHpipe, cat-back????, 3.73s, msd 9al, stormin norman with ram air, weld draglites, calypso gree florida car super clean oh and kenny brown subframes, lot of the work done by panhandle performance in FL, why do you ask???
1 - 20 of 22 Posts
