i just pulled the valve body to put in the b&m transpak. I pulled the 1-2 capacity modulator valve and bore plug and spring between them. the directions say to use the green spring instead of the stock spring. the problem is the green spring is only about 1/2 in long x .250 dia where the stock spring is 2 in long x .500 dia. I also tried to flip the 1-2 capacity modulator valve around the way it is in the directions and with it that way the spring clip wont go in to the bore plug in the right location. what gives? anybody have any ideas? b&m tech doesnt open til monday
Should have went w/ Lentech :)
sure if youre buyin
