1 - 9 of 9 Posts
· Registered
94-95 spindle and calipers. I do not know if there is a spindle that has some sort of offset bearing. Thank for help.
Tire Wheel Automotive tire Locking hubs Tread
· Registered
get a custom cap made or contact the manufacturer see if they make an extended cap to fit the wheel. This is a very common issue with fox wheels. There are plenty of wheels that have this problem. A lot of wheels specific for fox bodies that have exposed lugnuts have this problem.
· Registered
Those are not 94-95 spindles and brakes. Those are standard foxbody brakes with a 5-lug rotor (84-86 SVO). That's why the center cap protrudes so far.
You can tell by this mounting bolt here, which the fox style brakes use. SN95 calipers bolt on down behind the rotor. SN95 brakes won't be much better however, the center cap still protrudes, just not as much.
Wheel Tire Automotive tire Hood Automotive lighting
· Registered
Is the wheel bolted on or just mocked up?
1 - 9 of 9 Posts
