1 - 1 of 1 Posts
after priming the oil, and filling with nessissary fluids, anything else I should do before start up?
this is a rebuild engine, so how long do I baby it? and how long should I wait before I change the oil?
how many quarts of radiator fluid?
how many quarts of AOD fluid? I put one quart into the torque converter.....should I put more in to the converter?
what's a good fuel pressure to start out with with 30 lb inj?
can you set fuel pressure with out cranking over the engine? if you turn the key does the fuel pump still engage?
thanks
Jim
1 - 1 of 1 Posts
