I was thinking about puttin a line lock on my 94 GT. But I heard that if you put a lock on you can screw up the system when heating up the tires. I was wonder ing if anyone had a schematic diagram of the brake system. I want to put a cutout switch for the anti lock pump. So I can turn the pump off when doing a burnout. Does anyone know if this will stop the system from being damaged? And where I can find a schematic? I looked in my Haynes but no luck. I wonder if the ford service manual would have one. Any ideas? Thank you:confused:
For *A MUSTANG* ABS system, all you have to do is put the line lock in between the MC and the ABS unit. When you go to the track, just yank the ABS fuse. Even if you don't yank the fuse, you CAN NOT HURT the ABS with a line lock. At most, you'll "confuse" the ABS and cause the ABS light to come on until you turn the car off.
See my sig, then ABS, at the bottom of my main ABS page, you'll see a link to Joe L's site. Joe L has a Great write up and info.
