So this is combo isn't special. I went backwards. I put a stock 93 long block in. stock heads, cam, factory bore. the only thing aftermarket on it is trick flow r series intake with 75mm tb, old Motorsport shorties and old Motorsport h pipe 2.25"
change bore and stroke. 10 seconds
running the same fuel system from my 600+ sc ed 408
im running 75# injectors with np just increased the low slope number as per the simple instructions. took 5 minutes
i have the idle set at 850. again following simple directions took 3 minutes
set base timing. we all know how long that takes. 5 minutes
Didnt touch fuel or spark tables. didn't even look at them.
car runs beautiful. as expected. my 408 is on the stand. im looking through it, changing heads, cam, looking for about 700..
My 408 should be back in the car around june 1.
No dyno retune needed. Pro m pays for itself again.
